Re: [Nagios-devel] [SPAM] Re: BUG in history.cgi (+ fix)
------=_Part_2129_2506832.1213879990627
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
this will probably work, but won't it create a problem if sizeof(input) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 19/06/08 07:46 AM, Franky Van Liedekerke wrote:
> > Hi all,
> > I had some problems with history.cgi where it consistently coredumped on
> me.
> > After some searching, it seems that history.c assumes that each line in
> > nagios.log has a certain maximum lenght (MAX_INPUT_BUFFER) but some
> > plugins write more info away there (like the check_oracle_health plugin
> > in my case).
> > But the issue is: when such a long line is found, history.c doesn't chop
> > it off after MAX_INPUT_BUFFER characters and as such coredumps ...
> > Solution: add the line
> > input[MAX_INPUT_BUFFER]='\x0';
> > at around line 551 in cgi/history.c (before the "strip(input);" line),
> > so the code becomes:
> > printf("\n");
> > while(1){
> > free(input);
> > if(use_lifo==TRUE){
> > if((input=pop_lifo())==NULL)
> > break;
> > else{
> > if((input=mmap_fgets(thefile))==NULL)
> > break;
> > strip(input);
> > This solves my problem for now, but I don't know if it is the correct
> > solution of course ...
> I don't have time to test, but it looks like the segfault is just a few
> lines below:
> strcpy(input_buffer2,input);
> input_buffer2 has a static length of MAX_INPUT_BUFFER, so you should
> rather use strncpy and limit to "MAX_INPUT_BUFFER-1" characters (so it
> will be able to terminate it with a \0).
> Your fix will work just as well, but changing strcpy to strncpy is more
> obvious and use of strcpy is discouraged for that exact reason.
> Thomas
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFIWksC6dZ+Kt5BchYRAr50AKDHHDBPVizBG8rPGvs2eMYTtyWxVQCgqAvn
> zF/jM6g9ph5x6nqt92WiScQ=
> =Zyc7
> -----END PGP SIGNATURE-----
> Check out the new SourceForge.net Marketplace.
> It's the best place to buy or sell services for
> just about anything Open Source.
> http://sourceforge.net/services/buy/index.php
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=ISO-8859-1
Hi,this will probably work, but won't it create a problem if
sizeof(input) < MAX_INPUT_BUFFER? Probably my solution has that
problem as well ...Maybe we should use strlcpy here:
strlcpy(input_buffer2,input,MAX_INPUT_BUFFER-1);FrankyOn 6/19/08, Thomas Guyot-Sionnest <[email protected]> wrote:
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 On 19/06/08 07:46 AM, Franky Van Liedekerke wrote: > Hi all, > > I had some problems with history.cgi where it consistently coredumped on me.
...[email truncated]...
