Re: [Nagios-devel] Strange load average with Nagios 3
Yann Jouanin wrote:
>>> Has anyone the same observation ?
>> I've never seen anything like it before. Does the 4-hour interval coincide
>> with your check-interval? Does it align with some performance-data
> processing?
> No, we process performance data every 15 seconds (and even when stopping
> processing pattern still reproduced).
> Our check-interval are 1min and 5 min, it doesn't seem to be correlated with
> the 4hours slot.
>>> Can something in Nagios behavior explain
>>> this load ?
>> Not really, no. I suppose a database logging application could display a
> load
>> pattern such as this if it manages its tables really poorly and then
> vacuums
>> them at the peak of the load, but since you mentioned nothing about
> NDOUtils
>> or anything similar I'll just assume you have no such things installed.
> There is no mysql nor NDOUtils running on these servers.
> Only Nagios and PNP (NPCD + BULK)
>>> Our servers are running different Linux distributions and we spot out the
>>> fact that the pattern is certainly due to Nagios.
>> How did you ascertain this? Sorry for being skeptical, but I've seen
>> "Oh I'm really, really sure" followed by "oops turned out I was wrong"
>> too many times to trust other's eyes ;-)
> I can understand your skepticism, let's say we strongly guess (instead of
> certainly!) this is due to nagios:
> - stopping NPCD doesn't change the pattern.
> - we check cronjob, nothing was running with a 4 hour periodicity
> - the different servers don't run the same services (E.G : some
> have backup with bacula, some not)
> - We can unfortunately not stop the nagios process (because it's
> production!) but, the amplitude of lobes seems to be quite correlated with
> the number of services.
That seems to rule out the basics and some of the esoterics at least.
Does this state persist if you restart Nagios, or does it sort of grow
into place after it's been running a while?
It would be nice to be able to see average run-time of plugins over the
time of that graph. I could imagine long-running checks to sort of pile
up until they spill over and miss one of their check-windows, but that
*should* mean load slowly increased and then stayed at a small plateau.
In short; I have no idea what causes this behaviour.
OP5 AB www.op5.se
on peace.
