libraries for generation (and if you need it, parsing).
http://xml.apache.org/
Ethan, if you know HTML, you know XML!
another data format!
I'd be very happy to help out on this part, and I'm fairly familiar with XML.
I'm not not very familiar with C or C++. I can give it a whack if you want.
I guess I could do a quick example which parses the status.log? Converting
that to an XML in perl would be /really/ easy for me as well..
If there were one entry, you could do something like:
[1037341558]
SERVICE;stcalldb1;PING;OK;1/3;HARD;1037341411;1037341711;ACTIVE;1;1;1;1037338125
;0;OK;575;0;0;0;0;0;1;0;4;1;0;0.00;0;1;1;1;PING OK - Packet loss = 0%, RTA =
1.10 ms
stcalldb1
PING
...etc...
Nothing really that hard honestly.
-bk
Quoting Subhendu Ghosh :
> Might want to take a quick look at how Ganglia.sf.net does XML -
> relatively simple setup using XML to multicast host state information for
> a cluster.
> I'll try and write up a draft of the XML structure for discussion - It
> might also be handy for for a few other things in v2/v3
> -sg
> On Wed, 13 Nov 2002, Ethan Galstad wrote:
> > It has been mentioned by several people in the past that it would be
> > helpful if there was a way of getting status information in XML
> > format. NTray is one program that would benefit from this.
> > The easiest solution at the moment would be to write a CGI that does
> > this. However, I know very little about XML at the moment, so I need
> > assistance from people in the know. Specifically, what should the
> > output look like to make it easy to interpret?
> > There are 3 types of entities that have status data:
> > - Process status (1 entry)
> > - Host status (Multiple entries)
> > - Service status (Multiple entries)
> > I suppose it would be nice to be able to get access to comment and
> > downtime data in XML format as well, although that is less of a
> > priority that status data.
> > Comments? Suggestions?
> > Ethan Galstad,
> > Nagios Developer
> > Email: [email protected]
> > Website: http://www.nagios.org
> This sf.net email is sponsored by: To learn the basics of securing
> your web site with SSL, click here to get a FREE TRIAL of a Thawte
> Server Certificate: http://www.gothawte.com/rd524.html
> Nagios-devel mailing list
> [email protected]
