[Nagios-devel] Tinderbox
Nagios' tinderbox, http://tinderbox.nagios.org/nagios/status.html,
shows one buildbox as failing due to TAP::Parser missing. If the
person responsible for that systems is on this list, I'd take it
kindly if you could re-install that package.
Ton, if the build is still failing on that system in a week, could
you remove it from the tinderbox page?
OP5 AB www.op5.se
on peace.
