Hash: SHA1
On 11-01-27 04:01 PM, Tevfik Karagulle wrote:
> Hi,
> No need to integrate that patch into the main stream at the moment.
> Maybe it is too specific for a not-so-mainstream platform for Nagios
> world (cygwin).
> I just wanted to get some feedback about the way I did. I can see that
> it is not so straightforward to address needs of sysadmins sending their
> own commands directly.
> I will try to come up with some docs and optimizations. We can then
> discuss if it is worthwhile to be a part of the standard distribution.
Thanks. Well, I believe there's no better place for this code - once you
believe it's mature enough to be somewhat usable and properly
documented. Cygwin isn't supported right now so we won't break anything,
OTOH we'll give opportunity for others to look at it and add to it.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk1CNLsACgkQ6dZ+Kt5BchbKIQCeK8yRUe+cB+I5L0La86VXxK13
WGcAn07IlfyLT/S4aQIT2hRlb3YbYjd4
=dc4G
-----END PGP SIGNATURE-----
