perl available or not?
sailor
Post by sailor »
Nagios 3.2.3 on RedHat 5.6
Finally getting around to trying this out after installing it months ago. I'm trying to get a perl script to work. From config.log during during configure:
configure:7812: checking for perl
configure:7830: found /usr/bin/perl
configure:7842: result: /usr/bin/perl
ac_cv_path_PERL=/usr/bin/perl
PERL='/usr/bin/perl'
I can see in nagios.cfg:
enable_embedded_perl=1
use_embedded_perl_implicitly=1
My config:
$USER1$/check_apache.pl -H www.mywebsite.com -p 80 -t 5 -w 200 -c 100
On the console I get just "(null)". I can do a perl check_apache.pl fine outside of Nagios.
Any ideas?
tonyyarusso
Re: perl available or not?
Post by tonyyarusso »
My guess is that your check requires some feature / library of Perl that is not included in Nagios' embedded Perl interpreter. To check that, try disabling those embedded perl options and restarting Nagios, and see if you get a different result. If you do, then you can get around it by defining which checks should use the embedded perl and which should use the system's perl installation.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
sailor
Post by sailor »
I found it via only doing this. Other methods seem to work fine.
perl /usr/local/nagios/libexec/check_apache.pl -H mywbsite -po 80 -t 5 -w 200 -c 100
Can't locate utils.pm in @INC (@INC contains: /usr/lib/nagios/plugins /usr/lib64
8 /usr/lib/perl5/site_perl /usr/lib64/perl5/vendor_perl/5.8.8/x86_64-linux-threa
/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 .) at /usr/local/nag
BEGIN failed--compilation aborted at /usr/local/nagios/libexec/check_apache.pl l
[root@wsmkmap3t nagios]# perl /usr/local/nagios/libexec/check_apache.pl -H wsmkmwb1p.minoltana.minolta.com -p 80 -t 5 -w 200 -c 100
I came across this https://bugzilla.redhat.com/show_bug.cgi?id=196356
And yet, I have plugins nagios-plugins-1.4.15. I just copied the util in and the error is gone now.
Thanks for the hints.
sailor
Post by sailor »
I finally found an error by doing (and only this way (ie ./check_apache.pl works when in the libexec)):
perl /usr/local/nagios/libexec/check_apache.pl -H mywebsite.com -p 80
I came across this
and yet I'm have nagios-plugins-1.4.15. After copying utils.pm in, it's working ok now.
rdedon
Post by rdedon »
Hello sailor,
thank you for the update and sharing that with us :-)
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
tonyyarusso
Ah, that would do it. The utils.pm lives in /usr/local/nagios/libexec/, which plugins written only for Nagios installed from RPM/DEB don't expect.
Tony Yarusso
Technical Services
___
TIES
