Re: [Nagios-devel] some feature requests
Volker Maibaum wrote:
>> Brad O'Hara wrote:
>>> In line.
>>>>> Hi,
>>>>> I have some feature requests for nagios:
>>>>> - set contactgroups on host basis for services. So that if no
> contact is
>>>>> set for a service check the host contact group is used. That would
> make
>>>>> configuration a lot easier.
>>>> This I like.
>>>>> - It would be nice if it would be possible to categorise the
> criticality
>>>>> of services and hosts. E.g. critical / uncritical / unimportant.
> So that
>>>>> the operating could easily decide if they have to call somebody
> during
>>>>> midnight or if the problem can wait till the next morning.
>>>>> I know this could also be done by host and servicegroups, but it
> would
>>>>> be nicer to have this as a parameter. Depending on the category
> the
>>>>> host/service could be highlighted with different colours in the
>>>>> web-frontend.
>>>> This I don't. It's very, very simple to make the right contacts
> the
>>>> contacts of critical hosts and services and have any script you
> want
>>>> do the actual contacting, so adding complexity to the core to give
>>>> another way of doing the same thing doesn't sound very useful to
> me.
>>> True enough. Our problem is that we have operations staff monitor
>>> Nagios and notify people off hours based on how critical the
> "resource"
>>> is not the severity of the check.
>> Ok. Then you're not using the first alternative, which would be to
>> create a notification script for the contacts supposed to be on call
> for
>> the night. Nagios is fully capable of dialing your technical staff
> and
>> telling them that "this and this unit isn't functioning". I think
> you're
>> also aware that you can use several different notification-commands
>> (they don't have to notify, they can do anything you can make a
> computer
>> do, really), and this in combination with the possibility of setting
>> several or different contactgroups for each host and service is, imo,
> a
>> better solution than to implement configuration options. Mostly since
>> those options will easily become outdated, but also because of the
> need
>> to add more bloat to the core of Nagios.
> The problem is not only about notification. I could implement two email
> scripts, one that writes in the subject "critical" and one that writes
> "not so important". But if the staff looks at the web-frontend of nagios
> they don't see any difference. A "kernel panic" appears in the same way
> as "the soda machine is out of water". The operating staff that looks at
> nagios does not now that the soda machine is not critical. But they have
> to decide if we have a critical situation and if they have to call an
> expert.
> regards,
> Volker
Exactly why we built it into the naming convention, i.e. NSsoft--NC(or
CR)--aerv1-anm-1 (owning group--criticality--host name/service name).
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
Brad O'Hara E-mail: [email protected]
IT Expert Voice: (352)392-2061
Computing and Networking Services Suncom: 622-2061
University of Florida Fax: (352)392-9440
