Re: [Nagios-devel] broker call in disable_service_notifications
Good catch - patch will be in CVS shortly.
Marc DeTrano wrote:
> I believe I found a bug in commands.c, in : disable_service_notifications
> (around line 3540 or so in HEAD).
> The call to broker_adaptive_service_data comes before the switch to
> svc->notifications_enabled=FALSE.
> In enable_service_notifications, enable_host_notifications, and
> disable_host_notifications, the switch always comes before the broker is
> called. This means if you are trying to catch the disabling of
> service notifications in a broker module (as I am doing), you have no
> way to inspect the value of "notifications_enabled" to determine if this
> was just enabled or disabled.
> Hope this helps, and thanks for all the great work on Nagios.
> Marc DeTrano
> Gridshield, S.A.
- Ethan Galstad
