[Nagios-devel] [patch] postgresql abstime problem
--jRHKVT23PllUwdXP
Content-Disposition: inline
I found some problems using nagios and postgresql on my debian
distribution. My nagios version is 1.2 and postgres - 7.2.1-2woody4.
If someone has in logs something like this:
ERROR: Bad abstime external representation '1081320063'
this is by bad timestamp representation in: xdata/xcddb.c, xdata/xdddb.c
and xdata/xsddb.c files. The problem is with conversion which in
original source is for example: %lu::abstime::timestamp, when it should
be: %lu::int4::abstime::timestamp.
Patch is incuded in attachment.
In init.d script may be helpful changing line 107:
su $Nagios -c "touch $NagiosVar/nagios.log $NagiosSav".
Regards
M.S.
--jRHKVT23PllUwdXP
Content-Disposition: attachment; filename="nagios_xdata.patch"
*** nagios-1.2/xdata/xcddb.c Sat May 31 22:44:27 2003
--- nagios-1.2-new/xdata/xcddb.c Wed Apr 7 12:06:54 2004
*** 712,716 ****
#endif
#ifdef USE_XCDPGSQL
! snprintf(sql_statement,sizeof(sql_statement)-1,"INSERT INTO %s (host_nam=
e,persistent,entry_time,author_name,comment_data) VALUES ('%s','%d',%lu::ab=
stime::timestamp,'%s','%s')",XCDDB_HOSTCOMMENTS_TABLE,escaped_host_name,per=
sistent,entry_time,escaped_author_name,escaped_comment_data);
#endif
sql_statement[sizeof(sql_statement)-1]=3D'\x0';
--- 712,716 ----
#endif
#ifdef USE_XCDPGSQL
e,persistent,entry_time,author_name,comment_data) VALUES ('%s','%d',%lu::in=
t4::abstime::timestamp,'%s','%s')",XCDDB_HOSTCOMMENTS_TABLE,escaped_host_na=
me,persistent,entry_time,escaped_author_name,escaped_comment_data);
#endif
*** 810,814 ****
#endif
#ifdef USE_XCDPGSQL
e,service_description,persistent,entry_time,author_name,comment_data) VALUE=
S ('%s','%s','%d',%lu::abstime::timestamp,'%s','%s')",XCDDB_SERVICECOMMENTS=
_TABLE,escaped_host_name,escaped_svc_description,persistent,entry_time,esca=
#endif
--- 810,814 ----
#endif
#ifdef USE_XCDPGSQL
S ('%s','%s','%d',%lu::int4::abstime::timestamp,'%s','%s')",XCDDB_SERVICECO=
MMENTS_TABLE,escaped_host_name,escaped_svc_description,persistent,entry_tim=
#endif
*** nagios-1.2/xdata/xdddb.c Sat May 31 22:44:27 2003
--- nagios-1.2-new/xdata/xdddb.c Wed Apr 7 12:08:02 2004
*** 752,756 ****
#endif
#ifdef USE_XDDPGSQL
e,entry_time,author_name,comment_data,start_time,end_time,fixed,duration) V=
ALUES ('%s',%lu::abstime::timestamp,'%s','%s',%lu::abstime::timestamp,%lu::=
abstime::timestamp,'%d','%lu')",XDDDB_HOSTDOWNTIME_TABLE,escaped_host_name,=
entry_time,escaped_author_name,escaped_comment_data,start_time,end_time,fix=
ed,duration);
#endif
--- 752,756 ----
#endif
#ifdef USE_XDDPGSQL
ALUES ('%s',%lu::int4::abstime::timestamp,'%s','%s',%lu::int4::abstime::tim=
estamp,%lu::int4::abstime::timestamp,'%d','%lu')",XDDDB_HOSTDOWNTIME_TABLE,=
escaped_host_name,entry_time,escaped_author_name,escaped_comment_data,start=
_time,end_time,fixed,duration);
#endif
*** 850,854 ****
#endif
#ifdef USE_XDDPGSQL
e,service_description,entry_time,author_name,comment_data,start_time,end_ti=
me,fixed
...[email truncated]...
