Re: [Nagios-devel] Nagios dashboard...
--=-Av9Np5FIYsinSjGMzK11
Content-Disposition: inline
Hi Andreas,
>=20
> >=20
> > I've given your patch a try - it applies and complies just fine.=20
> But
> > there is a reference to a "status2.cgi" and a "dash-images"
> directory
> > (?) not included in the patch - could you point me where to find
> them
I've created a new patch file. It builds and runs on G4 Apple
Powerbook Mac OS X 10.5.8. Can you give it a try?
HTH, cu l8r, Edgar.
Content-Type: text/x-patch; charset=us-ascii; name=nagios-dashboard-3.0.6.patch
Content-Disposition: attachment; filename=nagios-dashboard-3.0.6.patch
diff -Naur nagios-3.0.6.old/cgi/Makefile.in nagios-3.0.6/cgi/Makefile.in
--- nagios-3.0.6.old/cgi/Makefile.in 2008-11-02 18:32:03.000000000 +0100
+++ nagios-3.0.6/cgi/Makefile.in 2009-08-15 11:43:59.000000000 +0200
@@ -24,6 +24,8 @@
=20
CGIEXTRAS=3D@CGIEXTRAS@
=20
+GDLIBS=3D-lgd
CP=3D@CP@
CC=3D@CC@
CFLAGS=3D@CFLAGS@ @DEFS@ @GLIB_INCLUDE@ -DNSCGI
@@ -155,7 +157,7 @@
$(CC) $(CFLAGS) $(LDFLAGS) -o $@ showlog.c $(CGILIBS) $(LIBS)
=20
status.cgi: status.c $(CGIDEPS) $(CDATADEPS)
- $(CC) $(CFLAGS) $(LDFLAGS) -o $@ status.c $(CGILIBS) $(CDATALIBS) $(LIBS)
+ $(CC) $(CFLAGS) $(LDFLAGS) -o $@ status.c $(CGILIBS) $(CDATALIBS) $(LIBS)=
$(GDLIBS)
=20
statuswml.cgi: statuswml.c $(CGIDEPS)
$(CC) $(CFLAGS) $(LDFLAGS) -o $@ statuswml.c $(CGILIBS) $(LIBS)
diff -Naur nagios-3.0.6.old/cgi/status.c nagios-3.0.6/cgi/status.c
--- nagios-3.0.6.old/cgi/status.c 2008-11-30 18:52:34.000000000 +0100
+++ nagios-3.0.6/cgi/status.c 2009-08-15 21:00:24.000000000 +0200
@@ -21,6 +21,21 @@
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
=20
+ * Dashboard entries for nagios 3.0.6
+#include
+#include
+#include
+#include
+#include
+#include
+#include "../include/locations.h"
+ * End dashboard
#include "../include/config.h"
#include "../include/common.h"
#include "../include/objects.h"
@@ -32,6 +47,17 @@
#include "../include/getcgi.h"
#include "../include/cgiauth.h"
=20
+#define STATUS2_CGI "status2.cgi"
+char *full_img_path =3D NULL;
+#define HTML_IMG_PATH "/nagios/dash-images"
+#define IMGSIZE 100
+ * End dashboard
extern int refresh_rate;
extern time_t program_start;
=20
@@ -78,6 +104,17 @@
#define STYLE_GRID 3
#define STYLE_HOST_DETAIL 4
=20
+#define STYLE_DASHBOARD 5
+#define NR_ARG_HOSTS 4
+#define NR_ARG_SERVICES 5
+ * End dashboard
/* HOSTSORT structure */
typedef struct hostsort_struct{
hoststatus *hststatus;
@@ -123,6 +160,25 @@
void show_hostgroup_grids(void);
void show_hostgroup_grid(hostgroup *);
=20
+void show_servicegroup_chart(servicegroup *);
+void show_hostgroup_chart(hostgroup *);
+void show_servicegroup_dashboard(void);
+void show_hostgroup_dashboard(void);
+void get_servicegroup_host_totals_summary(servicegroup *temp_servicegroup,=
int *r_up, int *r_down, int *r_unreachable, int *r_pending);
+void get_servicegroup_service_totals_summary(servicegroup *temp_servicegro=
up, int *r_ok, int *r_warning, int *r_unknown, int *r_critical, int *r_pend=
ing);
+void get_hostgroup_service_totals_summary(hostgroup *temp_hostgroup, int *=
r_ok, int *r_warning, int *r_unknown, int *r_critical, int *r_pending);
+void get_hostgroup_host_totals_summary(hostgroup *temp_hostgroup, int *r_u=
+char *mkchart(char *type, int nr, ...);
+char *uniquepngfile (char *type);
+int getlargest (int i1, int i2, int i3, int i4, int i5);
+ * End dashboard
void show_filters(void);
=20
int passes_host_properties_filter(hoststatus *);
@@ -327,33 +383,33 @@
e
...[email truncated]...
