[Nagios-devel] nagios init.d patch to set site-specific environment
------_=_NextPart_001_01C6A6BD.04AC7A02
Content-Type: text/plain;
charset="us-ascii"
I had trouble with the contrib/check_oracle_instance.pl plugin not
picking up my ORACLE_HOME and LD_LIBRARY_PATH environment variables, so
I patched the nagios daemon start/stop script in /etc/rc.d/init.d to
read environment variables from a site-specific file named 'nagios_env'
in the same directory as the .cfg files.
I think the attached patch will fix Makefile.in and daemon-init.in, and
the attached sample nagios_env file can go in sample-config. =20
One thing I can't figure out is how to make 'make install-config' not
overwrite the nagios_env file if you already have one; I think the whole
point would be to not overwrite it when you upgrade etc.
Comments? Feedback?
nathan vonnahme, system engineer at fairbanks memorial hospital
1650 cowles street, fairbanks alaska 99701. 907-458-5464
Content-Type: application/octet-stream;
name="nagios_env.diffu"
Content-Description: nagios_env.diffu
filename="nagios_env.diffu"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...[email truncated]...
