Hi Ethan et al,
We have developed a Servlet gateway to Nagios MySQL which might be
useful to some people. Perhaps more useful might be the XML definitions
that we have worked up and the other components of the data structure
etc.
If anyone is interested, am happy to share the XML definitions and the
Servlet code if that is of use !
Regards,
Mark Gillett
IXIF Limited, Commercial Support for NMS
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ethan
Galstad
Sent: 14 November 2002 03:39
To: [email protected]
Cc: [email protected]
Subject: [Nagios-devel] XML Output
It has been mentioned by several people in the past that it would be
helpful if there was a way of getting status information in XML
format. NTray is one program that would benefit from this.
The easiest solution at the moment would be to write a CGI that does
this. However, I know very little about XML at the moment, so I need
assistance from people in the know. Specifically, what should the
output look like to make it easy to interpret?
There are 3 types of entities that have status data:
- Process status (1 entry)
- Host status (Multiple entries)
- Service status (Multiple entries)
I suppose it would be nice to be able to get access to comment and
downtime data in XML format as well, although that is less of a
priority that status data.
Comments? Suggestions?
Ethan Galstad,
Nagios Developer
Email: [email protected]
This sf.net email is sponsored by: Are you worried about
your web server security? Click here for a FREE Thawte
Apache SSL Guide and answer your Apache SSL security
needs: http://www.gothawte.com/rd523.html
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
