On 01/28/2010 09:49 AM, Ton Voon wrote:
> Hi Jonathan,
> On 28 Jan 2010, at 02:28, Kamens, Jonathan wrote:
>> See the attached patch, nagios-3.2.0-startup-speed.patch, which
>> optimizes startup time. It requires the patch I sent last month. I've
>> also attached and updated version of that patch which has some bug
>> fixes in it. Enjoy!
> Thanks. I've noticed this too for comments and downtimes.
> I'm wondering if there is a better way of doing this. Rather than each
> caller having to work out the next comment id value and making sure it
> is still unique, I think the next_comment_id should be manipulated
> within xrddefault.c instead. If you call add_new_comment with a
> comment_id of 0, it uses next_comment_id and ensures it gets incremented.
> I guess on the initial load of retention.dat you have to validate that
> the next_comment_id is unique, but you shouldn't have to after that.
> Can you extend the tests in t-tap/ to time the performance increase?
> So I'm thinking that the patch needs a bit more work to be applied.
Seconded. The API should take care of making sure comment id's are
unique and incremental. In fact, passing a comment id to the API at
all is, to me, totally superfluous and counterproductive.
OP5 AB www.op5.se
on peace.
