--------------070101000809040209060507
Content-Type: text/plain; charset=ISO-8859-1
Please drop last patch... didn't read the man open right... sorry for that.
After cleaning up the checkresult dir nagios creates all needed files
(cXXXXXX + cXXXXXX.ok) properly.
@florian
can you please have a look at your checkresult spool dir and tell us if
there is a *.ok file for each cXXXXXX file?
In case that not please try this patch to get an error message to logs
and console to determine why nagios could not create that ok file.
Regards,
Hendrik
Content-Type: text/x-patch;
name="utils.c.debug.patch"
Content-Disposition: inline;
filename="utils.c.debug.patch"
Index: base/utils.c
RCS file: /cvsroot/nagios/nagios/base/utils.c,v
retrieving revision 1.180
diff -u -r1.180 utils.c
--- base/utils.c 9 Jun 2007 16:43:03 -0000 1.180
+++ base/utils.c 18 Jun 2007 16:05:00 -0000
@@ -4185,8 +4185,13 @@
/* create an ok-to-go indicator file */
asprintf(&temp_buffer,"%s.ok",output_file);
- if((output_file_fd=open(temp_buffer,O_CREAT|O_WRONLY|O_TRUNC,S_IRUSR|S_IWUSR))>0)
+ if((output_file_fd=open(temp_buffer,O_CREAT|O_WRONLY|O_TRUNC,S_IRUSR|S_IWUSR))>0){
close(output_file_fd);
+ else{
+ asprintf(&temp_buffer,"Error: Could not create ok file for %s: %d --%s--.\n",output_file,errno,strerror(errno));
+ write_to_logs_and_console(temp_buffer,NSLOG_RUNTIME_ERROR,TRUE);
my_free((void **)&temp_buffer);
/* delete the original file */
--------------070101000809040209060507--
