Re: [Nagios-devel] Bug report: downtimes beyond 2038 cause event
--20cf307c9b6a879fe804d98c9e2f
Content-Type: text/plain; charset=ISO-8859-1
Without having access to a computer, I'd venture a guess that time_t is too
small on centos 5. You might want to compare it to your Debian installation.
I think this is more likely to be a problem with "old glibc" than a problem
with your cpu architecture.
Best regards,
Anton
On 4 Apr 2013 18:55, "Ton Voon" wrote:
> Hi!
> We've come across a problem in an upgrade of Nagios 3 to Nagios 4 which we
> can't work out where the fix is. It occurs when an event is scheduled in
> the future beyond 2038.
> Recreation steps:
> * Set a downtime on a service to end next day
> * Stop Nagios
> * Edit the retention.dat so that the end_date=4514791088 (some other
> values seem to work)
> * Start Nagios
> When Nagios starts, it will not run any scheduled events in the events
> queue.
> This fails on CentOS 5 64bit, though appears to work on Debian Squeeze
> 32bit, so it maybe a 64 bit only issue.
> We think this is an issue when the event is scheduled via squeue_add().
> We've managed to get the test-squeue to fail by changing the time value to
> be greater than 2038 with the following:
> Index: test-squeue.c
> --- test-squeue.c (revision 2716)
> +++ test-squeue.c (working copy)
> @@ -116,7 +116,7 @@
> sq_test_random(sq);
> t(squeue_size(sq) == 0, "Size should be 0 after first
> sq_test_random");
> - t((a.evt = squeue_add(sq, time(NULL) + 9, &a)) != NULL);
> + t((a.evt = squeue_add(sq, time(NULL)*2, &a)) != NULL);
> t(squeue_size(sq) == 1);
> t((b.evt = squeue_add(sq, time(NULL) + 3, &b)) != NULL);
> t(squeue_size(sq) == 2);
> This gives the test result of:
> ### squeue tests
> FAIL max FAIL x == &b @test-squeue.c:133
> FAIL x->id == b.id @test-squeue.c:134
> FAIL x == &c @test-squeue.c:141
> about to fail pretty fucking hard...
> ea: 0xbfe065e0; &b: 0xbfe065d8; &c: 0xbfe065d0; ed: 0xbfe065c8; x:
> 0xbfde9b80
> FAIL x == &b @test-squeue.c:152
> FAIL x->id == b.id @test-squeue.c:153
> FAIL x == &b @test-squeue.c:160
> FAIL x->id == b.id @test-squeue.c:161
> FAIL x == &c @test-squeue.c:166
> FAIL x->id == c.id @test-squeue.c:167
> Test results: 390637 passed, 10 failed
> Changing to a factor of 1.1 instead of 2 passes:
> ### squeue tests
> Test results: 390647 passed, 0 failed
> This worked in Nagios 3, so we're guessing that the change to use the
> squeue library for events is probably where this limitation has come in.
> Any thoughts?
> Ton
> Minimize network downtime and maximize team effectiveness.
> Reduce network management and security costs.Learn how to hire
> the most talented Cisco Certified professionals. Visit the
> Employer Resources Portal
> http://www.cisco.com/web/learning/emplo ... index.html
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=ISO-8859-1
Without having access to a computer, I'd venture a guess=
that time_t is too small on centos 5. You might want to compare it to your=
I think this is more likely to be a problem with "old g=
libc" than a problem with your cpu architecture.
Best regards,
Anton
On 4 Apr 2013 18:55, "Ton Voon" <[email protected]> wrote:
Hi!
...[email truncated]...
