--0__=08BBFB07DFE9DE6A8f9e8a93df938690918c08BBFB07DFE9DE6A
Content-type: text/plain; charset=US-ASCII
I've found this sequence of what nagios does with event handler and status
file:
- host/service check finds state change, and calls event handler command
- event handler command does its processing, and either finishes or is
killed if runs longer than the nagios event handler timeout
- status.log is updated
Is there any way to get the status file updated before the event handler is
called?
Thanks for any help you can provide.
_____________________
Sean McKell
"Be noble! and the nobleness that lies in other men, sleeping but never
dead, will rise in majesty to meet thine own." - James Russell Lowell
Content-type: text/html; charset=US-ASCII
Content-Disposition: inline
I've found this sequence of what nagios does with event handler and status file:
- event handler command does its processing, and either finishes or is killed if runs longer than the nagios event handler timeout
Is there any way to get the status file updated before the event handler is called?
Sean McKell
"Be noble! and the nobleness that lies in other men, sleeping but never dead, will rise in majesty to meet thine own." - James Russell Lowell
--0__=08BBFB07DFE9DE6A8f9e8a93df938690918c08BBFB07DFE9DE6A--
