Re: [Nagios-devel] Nagios3 Performance Info
For some reason there was a large negative value in the status file
which was throwing off the results. Not sure why this happened, unless
there was a time change during the service check. I couldn't find any
obvious problems in the code, so I added a few checks to make sure the
execution time is always >= 0. Patch will be in CVS shortly.
Thomas Stolle wrote:
> Here is a copy of status.dat (gzip) at the moment the negative values
> were present:
> The type of the browser doesn't seems to be responsible for this. We
> tested mozilla and ie and both displayed these values.
> After a short time (may be one minute) the execution time switched back
> to normal values without any action from my side, so it is not a big
> problem but a little bit unusual ;-)
> Thomas
> *Ethan Galstad *
> Sent by: [email protected]
> 03.01.2007 01:38
> To
> Nagios-Devel
> cc
> Subject
> > Dear List,
> > 1.) sporadic I get negative values for check execution time in
> > "performance info" of nagios3. I can not reproduce this behaviour.
> > Check Execution Time: -1167735239.71 sec
> 5.01 sec -1307653.816 sec
> > Check Latency: 0.00 sec 162.52 sec
> 143.760 sec
> > Percent State Change: 0.00% 79.47%
> 0.88%
> > 2.) Even with disabled hostchecks (no check_command in host definition)
> > the hostcheck-counter in "performance info" of nagios3 starts counting.
> > I can not find any entries of hostchecks in the logs. Thats why I think
> > the checks were not really executed. Also the hostcheck execution time
> > is very short (0.05 sec) .
> > I don't know if this is a bug, if it is new in Nagios 3 or if the same
> > behaviour can be found in Nagios 2, cause I can only compare to
> > nagios1.2, which does not offer performance info for hostchecks.
> > Thomas
> Any chance you can grab a copy of the status.dat file when you see these
> values? I'd like a chance to look at the raw file to see what's going
> on (CGI problem, status data problem, etc.). Thanks.
Ethan Galstad,
Nagios Developer
Email: [email protected]
