Re: [Nagios-devel] Event Profiler Patch
Mathieu Gagné wrote:
> On 6/5/09 6:29 PM, Steven D. Morrey wrote:
>> p.s. Let me know how that patch goes on a 3x system I don't have a
>> running 3x to test it on, so all i can promise with that one is that it compiles :)
> I'm trying it on a Nagios 3.0.6 system. Note that I had to remove all
> references to EVENT_CHECK_PROGRAM_UPDATE because it's an event only
> available in Nagios 3.1.x.
> All volatile data are already located on tmpfs partitions. So I'll have
> to try without tmpfs partitions afterward so I can compare impact on
> performances.
Steve, thanks for the patch. Mathieu, thanks for testing it out. If it's
useful to you, I'll apply it and make sure it's included in 3.1.1. The
data we might be able to gather from it may well be important for the
3.2.0 release.
OP5 AB www.op5.se
on peace.
