--_002_3679AE44D8C04547A4F3EB83E77905628241945A46MBX01ldschurc_
Content-Type: text/plain; charset="us-ascii"
Hello Folks,
Here is a version with the event profiler as a config file option.
To turn it on or off, just set event_profiling_enabled=3D1 or 0 respectivel=
y.
You still need to compile with -DEVENT_PROFILER for it to work, but at leas=
t this way you can start and stop the profiler at will.
Sincerely,
Steve
________________________________________
Sent: Monday, June 08, 2009 9:30 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Event Profiler Patch
Steven D. Morrey wrote:
> I made it a compile time option in my patch for ease of insertion in
> the existing code base. It would be trivial to convert it to a config
> file option. Just add a new option and track it with a global
> variable, then search and replace all of the #ifdef EVENT_PROFILE
> tags with a simple if(gEvent_Profile_Enabled) After that it's just a
> matter of tracking down the unmatched #endif's and that should be it.
> If there is interest in it, I can update the code to do this and
> submit a new patch.
That would be preferrable, but please stick to the current style of
naming variables. "event_profiling_enabled" would be an acceptable
variable name.
OP5 AB www.op5.se
on peace.
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you are not the =
intended recipient, please contact the sender by reply email and destroy al=
l copies of the original message.
Content-Type: text/x-patch; name="nagios-3-event_profiler.patch"
Content-Description: nagios-3-event_profiler.patch
Content-Disposition: attachment; filename="nagios-3-event_profiler.patch";
size=25425; creation-date="Mon, 08 Jun 2009 16:58:47 GMT";
modification-date="Mon, 08 Jun 2009 16:58:47 GMT"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...[email truncated]...
Original poster: ndreas Ericsson [[email protected]
