Re: [Nagios-devel] to few notificationlevels in nagios
[email protected] wrote:
> Hi -
> In nagios v1.x (and possibly in 2.x) we have these notificationlevels: ok, warning and critical.
> I would like to have more notificationlevels to play with.
> If we compare with IBMs Tivoli they have several more levels Harmless,Warning,Minior,Critical and Fatal.
> Tivoli also enables you to define your own level (not to straightforward though)
> It seems to me that it would be easy to implement new levels in nagios also.
> F.x.a return-code of 4 might be defined as "fatal" or "catastrophic"
Nagios does this too, but with a much higher level of granularity,
through the use of escalations. That way you can specify for how long a
critical state should be considered non-fatal, which is something Tivoli
can't do.
OP5 AB www.op5.se
