[Nagios-devel] Bad object data always outputs line 0
--------------000601020206050505030602
Content-Type: text/plain; charset=us-ascii; format=flowed
In xdata/xodtemplate.c, the function xodtemplate_process_config_file()
doesn't accurately keep track of what line it's currently on.
It's not really serious, but annoying just the same.
The attached patch takes care of it.
OP5 AB www.op5.se
Lead Developer
name="nagios-HEAD-lines_read.diff"
Content-Disposition: inline;
filename="nagios-HEAD-lines_read.diff"
diff -urN ../../Nagios/xdata/CVS/Entries ./xdata/CVS/Entries
--- ../../Nagios/xdata/CVS/Entries 2004-12-03 13:54:31.000000000 +0100
+++ ./xdata/CVS/Entries 2004-12-03 13:16:08.000000000 +0100
@@ -10,5 +10,5 @@
/xsddefault.h/1.3/Fri Nov 5 14:18:53 2004//
/xpddefault.c/1.19/Wed Dec 1 19:16:03 2004//
/xpddefault.h/1.7/Wed Dec 1 19:16:03 2004//
-/xodtemplate.c/1.89/Fri Dec 3 12:54:25 2004//
+/xodtemplate.c/1.89/Fri Dec 3 12:16:08 2004//
D
diff -urN ../../Nagios/xdata/xodtemplate.c ./xdata/xodtemplate.c
--- ../../Nagios/xdata/xodtemplate.c 2004-12-03 13:54:25.000000000 +0100
+++ ./xdata/xodtemplate.c 2004-12-03 13:54:53.000000000 +0100
@@ -545,7 +545,6 @@
int result=OK;
register int x;
register int y;
- int lines_read=0;
char *ptr;
#ifdef NSCORE
char temp_buffer[MAX_INPUT_BUFFER];
@@ -590,7 +589,7 @@
if((input=mmap_fgets(thefile))==NULL)
break;
- current_line+=lines_read;
+ current_line++;
/* skip empty lines */
if(input[0]=='#' || input[0]==';' || input[0]=='\r' || input[0]=='\n')
--------------000601020206050505030602--
