On 06/22/2012 08:57 PM, Ricardo Maraschini wrote:
> hello,
> i've removed two unused variables on found_macro_x() function.
> Compiler errors:
> ../common/macros.c: In function ‘process_macros_r’:
> ../common/macros.c:133:6: warning: variable ‘found_macro_x’ set but not used [-Wunused-but-set-variable]
> ../common/macros.c:128:6: warning: variable ‘x’ set but not used [-Wunused-but-set-variable]
> OK? Comments?
Test this with macro resolution debugging turned on. I just
reverted a patch that did this change (and a bunch of other
-Wunused-but-set-variable), and removing the unused ones
actually broke macro resolution for the core.
OP5 AB www.op5.se
on peace.
