------_=_NextPart_001_01C4A0E3.3DDBD096
Content-Type: multipart/alternative;
boundary="----_=_NextPart_002_01C4A0E3.3DDBD096"
------_=_NextPart_002_01C4A0E3.3DDBD096
Content-Type: text/plain;
charset="US-ASCII"
Posted this to the users group...figured the development list would be
helpful now. Also, have reconfigured nagios.conf to use performance
data...now the process stays running, so it appears (from the stack as
well) that perfdata configuration is causing the problem- =20
=20
So I did some research. It turns out that process_performance_data can
be set to 0 and everything still works, in fact all of the remaining
options for performance data can be commented except:
service_perfdata_file=3D/tmp/service-perfdata
=20
If that definition does not exist, a SEGV gets generates...so I am
officially request a bug fix
runs as long as I define the file.
=20
=20
I have applied the patch :=20
http://article.gmane.org/gmane.network. ... devel/1108 and still have
the same problem.
=20
I've searched the threads and followed all of the advice I could find on
this issue. I am getting an SEGV while trying to start the nagios
process. I am running SUSE Linux 8 for Z/OS (Z900 Mainframe).
=20
I've attached a gzip with the full trace, but unfortunately, I do not
have enough knowledge to debug. I'd appreciate any suggestions! I've
already looked at permissions issues and started over with the base
configurations. I have compiled with DEBUGALL and am not using the
embedded Perl stuff.
=20
=20
################ STATUS and STACK INFO #################
(gdb) info program
Using the running image of child Thread 1024 (LWP 1588).
Program stopped at 0x4013a780.
It stopped with signal SIGSEGV, Segmentation fault.
(gdb) info stack
#0 0x4013a780 in strlen () from /lib/libc.so.6
#1 0x4013a4a0 in strdup () from /lib/libc.so.6
#2 0x004450ba in xpddefault_initialize_performance_data ()
#3 0x00444e1c in initialize_performance_data ()
#4 0x0040b59c in main ()
#5 0x400d97bc in __libc_start_main () from /lib/libc.so.6
#6 0x0040affc in _start ()
=20
=20
- Dan Goggiano
Computer Operations Manager
State of Nevada
Department of Information Technology
(775) 684-4306
=20
This communication, including any attachments, may contain confidential
information and is intended only for the individual or entity to it is
addressed. Any review, dissemination or copying of this communication by
anyone other than the intended recipient is strictly prohibited. If you
are not the intended recipient, please contact the sender by reply
e-Mail and delete all copies of the original message.
=20
Content-Type: text/html;
charset="US-ASCII"
st1\:*{behavior:url(#default#ieooui) }
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
pre
{margin:0in;
font-size:10.0pt;
font-family:"Courier New";}
span.EmailStyle18
{mso-style-type:personal;
font-family:
...[email truncated]...
