I move this thred to 'dev' instead. It seems to fit better there.
Problem solved.=20
Nagios does'nt check the return value from the fclose() call when
closing the tempfile used to write retention.dat. Before I upgraded to
Nagios 3 I hade severe performance problems, so I moved all temp-files
to ramdisks for higher performance which worked well. But when the
number of services increased after upgrading the ramdisk was'nt big
enough.
Since there were no log entry, and the ramdisks were only about 40-50%
full, I did'nt think this was the problem - after all the ramdisk were
only 100% full between the closing of the tempfile until Nagios changed
the name of the tempfile to "retention.dat".
Anyway. I've rewritten the code a little so that Nagios checks the
fclose() return value, and if there is a problem a log entry is written.
Also Nagios does not change the name of the tempfile, so the old
retention data is saved instead of the new corropt data.
Are you people interested in the patch?
Best Regards
/Markus almroth
-----Original Message-----
From: Andreas Ericsson [mailto:[email protected]]=20
Sent: den 14 november 2008 14:12
To: Almroth, Markus M.
Cc: [email protected]
Subject: Re: [Nagios-users] Nagios retention problem.
[email protected] wrote:
> Does anybody know if Nagios _always_ write the retention file when=20
> reloading/restarting?
> =20
It writes the retention file with rather frequent intervals, such as
when it has done "enough" checks (where "enough" is determined sort of
intelligently on a per-installation basis).
Didn't the command-file trick work for you?
--=20
OP5 AB www.op5.se
Original poster: ndreas Ericsson [mailto:[email protected]]=2
