Patch to get Nagios header files also installed
Hi Nagios developers,
some days ago I sent a patch for Nagios build system to get also
header files installed. The idea behind was, to ease the build of NEB
modules. There was no response at the mailing list, so I give it
another try. Anybody?
Thanks.
Tobias
---------- Forwarded message ----------
Date: 17.12.2007 21:03
Subject: Patch to get Nagios header files also installed
To: [email protected]
it would be more easy for developers to distribute and users to build
NEB modules if Nagios would be installed with its header files. I have
written a patch for configure.in, Makefile.in and include/Makefile.in
to support this. The latter is completely new since it didn't exist
yet. I used the existing include/Makefile as a starting point.
diff -up nagios-3.0b7/configure.in nagios-3.0b7-new/configure.in
--- nagios-3.0b7/configure.in 2007-11-23 19:24:50.000000000 +0100
+++ nagios-3.0b7-new/configure.in 2007-12-17 23:49:25.000000000 +0100
@@ -5,6 +5,7 @@ define([AC_CACHE_LOAD],)
define([AC_CACHE_SAVE],)
AC_INIT(base/nagios.c)
+dnl Files given in AC_CONFIG_HEADER don't have to get installed by
make, see include/Makefile.in
AC_CONFIG_HEADER(include/config.h include/snprintf.h include/cgiutils.h)
AC_PREFIX_DEFAULT(/usr/local/nagios)
@@ -758,7 +759,7 @@ AC_SUBST(INITDIR)
AC_SUBST(INSTALLPERLSTUFF)
AC_PATH_PROG(PERL,perl)
-AC_OUTPUT(Makefile subst pkginfo base/Makefile common/Makefile
contrib/Makefile cgi/Makefile html/Makefile module/Makefile
xdata/Makefile daemon-init html/index.html html/side.html)
+AC_OUTPUT(Makefile subst pkginfo base/Makefile common/Makefile
contrib/Makefile cgi/Makefile html/Makefile include/Makefile
module/Makefile xdata/Makefile daemon-init html/index.html
html/side.html)
perl subst include/locations.h
diff -up nagios-3.0b7/Makefile.in nagios-3.0b7-new/Makefile.in
--- nagios-3.0b7/Makefile.in 2007-11-10 23:54:35.000000000 +0100
+++ nagios-3.0b7-new/Makefile.in 2007-12-17 23:36:36.000000000 +0100
@@ -1,7 +1,7 @@
# Makefile for Nagios
-# Last Modified: 11-10-2007
+# Last Modified: 12-17-2007
@@ -28,6 +28,7 @@ BINDIR=@bindir@
CGIDIR=@sbindir@
LIBEXECDIR=@libexecdir@
HTMLDIR=@datadir@
+INCLUDEDIR=@includedir@
INSTALL=@INSTALL@
INSTALL_OPTS=@INSTALL_OPTS@
COMMAND_OPTS=@COMMAND_OPTS@
@@ -175,6 +176,7 @@ install-cgis:
install:
cd $(SRC_BASE) && $(MAKE) $@
cd $(SRC_CGI) && $(MAKE) $@
+ cd $(SRC_INCLUDE) && $(MAKE) $@
cd $(SRC_HTM) && $(MAKE) $@
$(MAKE) install-basic
@@ -185,6 +187,7 @@ install-unstripped:
install-basic:
+ $(INSTALL) -m 755 $(INSTALL_OPTS) -d $(DESTDIR)$(INCLUDEDIR)
$(INSTALL) -m 775 $(INSTALL_OPTS) -d $(DESTDIR)$(LIBEXECDIR)
$(INSTALL) -m 775 $(INSTALL_OPTS) -d $(DESTDIR)$(LOGDIR)
$(INSTALL) -m 775 $(INSTALL_OPTS) -d $(DESTDIR)$(LOGDIR)/archives
--- nagios-3.0b7/include/Makefile 2007-10-18 14:57:22.000000000 +0200
+++ nagios-3.0b7-new/include/Makefile.in 2007-12-18
00:12:30.000000000 +0100
@@ -1,9 +1,14 @@
# Makefile for Include Files
-# Last Modified: 10-18-2007
+prefix=@prefix@
+INSTALL=@INSTALL@
+INSTALL_OPTS=@INSTALL_OPTS@
clean:
rm -f *~
@@ -11,3 +16,14 @@ distclean: clean
rm -f cgiutils.h config.h locations.h snprintf.h
devclean: distclean
+install:
+ $(MAKE) install-basic
+install-basic:
+ for file in *.h; do \
+ if test "x${file}" != "xconfig.h" -a "x${file}" !=
"xsnprintf.h" -a "x${file}" != "xcgiutils.h" ; then \
+ $(INSTALL) -m 644 $(INSTALL_OPTS) $$file
$(DESTDIR)$(INCLUDEDIR); \
+ fi; \
+ done
...[email truncated]...
