[Nagios-devel] Re: NSCA daemon never writes to nagios.cmd or nsca.dump
On Jan 22, 2004, at 3:12 PM, Marc Powell wrote:
> I'm not familiar with issues on OSX in particular but the distributed
> model does work on other unices and the type of error you're seeing is
> usually related to security restrictions either within nsca or
> inetd/TCP
> wrappers (or the OSX equivalent). If you have debug turned on (and it
> looks like you do), you would see a lot more information in your syslog
> if it was progressing beyond that initial IP/password/encryption check.
> If you're really desparate, you might try to find an OSX equivalent of
> strace/truss to actually attach to the process and see what it's doing.
> Marc
Looks like ktrace is on OS X... going to use that and I will followup...
noah
