Re: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults after
On Thursday February 14 2008 10:40:15 am Masopust, Christian wrote:
> Hello,
> do you have NDO enabled? If yes, try to disable it and then restart
> Nagios. Maybe the ndo-version doesn't fit to your Nagios version...
no, NDO is not activated.
Regards,
Christian
> christian
> "I sense much NT in you, NT leads to Blue Screen.
> Blue Screen leads to downtime, downtime leads to suffering. NT is the path
> to the darkside."
> - Unknown Unix Jedi
> > -----Original Message-----
> > From: [email protected]
> > [mailto:[email protected]] On Behalf
> > Of Christian Schneemann
> > Sent: Thursday, February 14, 2008 10:38 AM
> > To: [email protected]
> > Subject: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults
> > after starting
> > Hallo,
> > our test Nagios dies after every restart with a segmentation
> > fault since last
> > week.
> > I have tried to find the error with gdb. I hope someone can
> > point me to my
> > error.
> > d139:/etc/nagios/objects/hosts #
> > gdb --args /usr/sbin/nagios /etc/nagios/nagios.cfg
> > GNU gdb 6.6
> > Copyright (C) 2006 Free Software Foundation, Inc.
> > GDB is free software, covered by the GNU General Public
> > License, and you are
> > welcome to change it and/or distribute copies of it under
> > certain conditions.
> > Type "show copying" to see the conditions.
> > There is absolutely no warranty for GDB. Type "show
> > warranty" for details.
> > This GDB was configured as "x86_64-suse-linux"...
> > (no debugging symbols found)
> > Using host libthread_db library "/lib64/libthread_db.so.1".
> > (gdb) run
> > Starting program: /usr/sbin/nagios /etc/nagios/nagios.cfg
> > [Thread debugging using libthread_db enabled]
> > [New Thread 47105982427648 (LWP 15658)]
> > Nagios 3.0rc2
> > Copyright (c) 1999-2008 Ethan Galstad (http://www.nagios.org)
> > Last Modified: 01-29-2008
> > License: GPL
> > Nagios 3.0rc2 starting... (PID=3D15658)
> > Local time is Tue Feb 12 10:37:24 CET 2008
> > [New Thread 1082132800 (LWP 15661)]
> > Program received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread 47105982427648 (LWP 15658)]
> > 0x000000000043b90a in process_check_result_queue ()
> > (gdb) bt
> > #0 0x000000000043b90a in process_check_result_queue ()
> > #1 0x000000000041c536 in reap_check_results ()
> > #2 0x0000000000429119 in handle_timed_event ()
> > #3 0x0000000000429701 in event_execution_loop ()
> > #4 0x00000000004120fe in main ()
> > (gdb) s
> > Single stepping until exit from function process_check_result_queue,
> > which has no line number information.
> > 0x0000000000437c50 in sighandler ()
> > (gdb) s
> > Single stepping until exit from function sighandler,
> > Caught SIGSEGV, shutting down...
> > 0x00002ad7b7394c10 in __restore_rt () from /lib64/libc.so.6
> > (gdb) s
> > Single stepping until exit from function __restore_rt,
> > (gdb) s
> > (gdb)
> > Regards
> > SUSE LINUX Products GmbH,
> > Maxfeldstr. 5, D - 90409 N=FCrnberg
> > Phone:=A0=A0+49 (0)911 - 740 53 0
> > e-mail:=[email protected]
> > SUSE LINUX Products GmbH, GF: Markus Rex
> > HRB 16746 (AG N=FCrnberg)
> > This SF.net email is sponsored by: Microsoft
...[email truncated]...
