Re: [Nagios-devel] Nagios3.0b4 Solaris9 compile issue
Found the bug - patch will be in CVS shortly...
David Halik wrote:
> It seems as though it's not limited to suncc. I just tried rebuilding it
> with GCC 4.2.1 and it fails in the exact same way. No one else has seen
> this whatsoever? Seems strange that it would fail in both GCC and SunCC
> and yet be limited to only my system.
> David Halik wrote:
>> Does anyone have any clues about this? I still haven't been able to get
>> past the use_large_installation_tweaks building issue. I'm guessing it's
>> not apparent in gcc since suncc is much more strict. Any help would be
>> appreciated.
>> Thanks,
>> -Dave
>> David Halik wrote:
>>> Hi all,
>>> I've been building Nagios3 betas1-3 without any issues, but with this
>>> latest release I ran into a compile problem. Using Sun Studio on
>>> Solaris 9 I'm seeing this:
>>> cc -I/usr/local/include -DHAVE_CONFIG_H -I/usr/local/include/glib-2.0
>>> -I/usr/local/lib/glib-2.0/include -DNSCGI -L/usr/local/lib
>>> -R/usr/local/lib -L/usr/sfw/lib -R/usr/sfw/lib -L/usr/local/lib -o
>>> config.cgi config.c getcgi.o cgiutils.o cgiauth.o macros-cgi.o
>>> ../common/snprintf.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o
>>> xstatusdata-cgi.o comments-cgi.o downtime-cgi.o -lrt -L/usr/local/lib
>>> -lglib-2.0 -liconv "cmd.c", line 2296: warning: no explicit type given
>>> for parameter: cmd
>>> "config.c", line 135: warning: implicit function declaration: init_macros
>>> "config.c", line 473: warning: implicit function declaration:
>>> grab_host_macros
>>> Undefined first referenced
>>> symbol in file
>>> use_large_installation_tweaks macros-cgi.o
>>> ld: fatal: Symbol referencing errors. No output written to cmd.cgi
>>> gmake[1]: *** [cmd.cgi] Error 1
>>> gmake[1]: *** Waiting for unfinished jobs....
>>> "config.c", line 1203: warning: implicit function declaration:
>>> grab_service_macros
>>> symbol in file
>>> ld: fatal: Symbol referencing errors. No output written to config.cgi
>>> gmake[1]: *** [config.cgi] Error 1
>>> symbol in file
>>> ld: fatal: Symbol referencing errors. No output written to avail.cgi
>>> gmake[1]: *** [avail.cgi] Error 1
>>> use_large_installation_tweaks never gave me any troubles before, was
>>> this something that was recently added? I'm guessing it's defined
>>> somewhere that's not being linked to, but a quick grep shows me its
>>> just in check.c, config.c, events.c, nagios.c, macros.c, and utils.c
>>> rather than any header references.
>>> Any help would be appreciated.
>>> Thanks,
>>> -Dave
Ethan Galstad,
Nagios Developer
Email: [email protected]
