> 2009/9/7 Hiren Patel :
>> could you switch on debugging on the nrpe server and paste the logs from
>> running your tests again please, is this the case with any plugin type
>> (something either than check_disk)?
Also tested with check_load:
# After restart
spmon:~/tmp/analisis # /usr/lib/nagios/plugins/check_nrpe -H billbd2
-c check_load -a 10,9,8 15,14,13
CRITICAL - load average: 16.12, 12.39,
12.48|load1=16.125;10.000;15.000;0; load5=12.391;9.000;14.000;0;
load15=12.484;8.000;13.000;0;
spmon:~/tmp/analisis # echo $?
2
# Second execution
CRITICAL - load average: 17.09, 12.72,
12.59|load1=17.090;10.000;15.000;0; load5=12.723;9.000;14.000;0;
load15=12.594;8.000;13.000;0;
0
# Running it locally
[root@billbd2 log]# /usr/local/nagios/libexec/check_load -w 10,9,8 -c 15,14,13
CRITICAL - load average: 15.08, 12.69,
12.59|load1=15.078;10.000;15.000;0; load5=12.691;9.000;14.000;0;
load15=12.590;8.000;13.000;0;
[root@billbd2 log]# echo $?
2
WARNING - load average: 14.81, 12.67,
12.58|load1=14.809;10.000;15.000;0; load5=12.668;9.000;14.000;0;
load15=12.582;8.000;13.000;0;
1
The truss log can show system calls made during the NRPE response
(like strace on linux).
Regards,
Ciro Iriarte
http://cyruspy.wordpress.com
