Re: [Nagios-devel] Bug Report: hostgroup_members with no
Hi Ethan,
I've checked the latest cvs version. It works! The bug is fixed :-)
Thank you.
Take care,
Gerd
On Di, 2008-02-12 at 22:45 -0600, Ethan Galstad wrote:
> Gerd Mueller wrote:
> > Hi Ethan!
> >=20
> > Do you remember my last bug report? I think it's still not fully solved=
> > The "pre-flight check" now comes back with no errors but the
> > precache-objects step is still buggy. Recursion is only done for the
> > first hostgroup_member of the first hostgroup. In this example hostgrou=
p
> > "a" only get the members of hostgroup "b" but hostgroup "c" will be
> > ignored.
> >=20
> > Cheers,
> >=20
> > Gerd
>=20
> This is a confirmed bug. It works properly sometimes, but not always -
> which is also a bug. :-) Whether it works correctly or not is currently
> dependent on the order in which you define hostgroups in the config file.
>=20
> I'll look at rewriting the affected portion of the logic for rc3. FYI,
> this bug is also present in the contactgroup and servicegroup logic. :-(
>=20
>=20
> Ethan Galstad
> Nagios Developer
> ___
> Email: [email protected]
> Web: www.nagios.org
>=20
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Nagios-devel mailing list
> [email protected]
--=20
Gerd Mueller =20
Senior Consultant
NETWAYS GmbH | Deutschherrnstr. 47a | D-90429 N=FCrnberg=20
Tel: +49 911 92885-0 | Fax: +49 911 92885-33=20
GF: Julian Hein | AG N=FCrnberg HRB18461=20
=20
http://www.netways.de | [email protected]=20
