On 18/12/09 09:47 AM, nap wrote:
> There are some proposal of new properties for hosts/services:
> *critical_is_warning (host, service, implicit inheritance from host to service)
> *hot_period (host, service, implicit inheritance from host to service)
> and:
> *inverse_ok_critical (service only).
> Theses properties are used for no production hosts.
> == Qualification and developement hosts ==
> There something I use to do : the Critical state is for Production
> only. When someone see the Nagios web site, a red mean : "to do now".
> Orange is "must be done". But a Red in a qualification host can be
> less important than a warning in a production server.
> That why all my checks are double :
> normal command :
> $USER1$/check_blabla -h $HOSTADRESS$
> qualification command:
> $USER1$/nocritical.sh "$USER1$/check_blabla -h $HOSTADRESS$"
> nocritical.sh is a dumb script that launch $1 and if return_code == 2
> -> return_code =1.
You should use "negate" - it comes with the official plugins and was
written specifically for this. Newer versions are more customisable and
can even change the status text as well.
> But It need 2 times checks and 2 times services too. I think we can
> nearly divide by 2 the number of services with a new host/service
I solved this with custom macros. In your root service template, add a
blank macro called _NEGATE, then whenever you need to negate a service
set _NEGATE to the full path and command to "negate" and arguments
(Note: macros aren't enabled there).
Then in your command definition, before the actual command add
$_SERVICENEGATE$. This actually give more flexibility as sometimes you
need different negate options.
> property : critical_is_warning. For the host, the only interest is to
> be inherited by the service (an host DOWN is always important, no 2->
> 1 here). And in a qualification host, nearly all services are in low
> priority (max = Warning), but some can be still Critical (like
> security services). So this property need to be add to the host for
> service implicit inheritance (default = 0) and to service (default =0
> too) to be set at 1 for trully important services.
> The hot_period can be add in host and service too (same for implicit
> inheritance). the idea is to "tag" low priority host with
> critical_is_warning. But some hosts are production just in some
> periods (like at the end of the month for financial servers). So you
> put hot_period in host (or service) and in this period critical is
> still critical. So In all the other times, this low level host is a
> low level host. If not specified, there is no hot_period (so always
> low level).
I'm not necessarily arguing against this one, but IMHO time periods
cover this pretty much. Using service escalations in conjunction with
timeperiods allow you sending alerts to different places (ex pager vs.
email) depending on time/date. Furthermore changing the returned result
of a plugin based on date/time might be more confusing as when a state
change occur you'd normally assume that the checked item actually changed.
Thomas
