[Nagios-devel] mysql enabled - can't see data on web page (netscape plugin)
I enabled mysql support for the full monty accept objects. If I look in the
database nagios at its tables, which I created with the
contrib/create_mysql, I see data, but if I go to the web page and try to
view the data, a netscape plug-ins box pops up and tries to have me download
a plugin called NPNetRecall.jar. It is only compatible with netscape 4.x
though, and I use netscape 6. The page also says:
It appears as though you do not have permission to view information for any
of the services you requested.
Ah, how do I see the data on the web page now that I am using 1.0.6a?
David E. Shapiro
Senior Unix Admin
BTi - the future of communications
