Re: [Nagios-devel] Logging API revamp
Andreas Ericsson wrote:
>>> So, I started looking into revamping the event queue logic, but ended up
>>> with a migraine from the cumbersome way logging is done, so I decided to
>>> try doing something about it, and the attached 3-patch series is the
>>> result from it.
>>> It compiles alright, both for nagios and the cgi's. I haven't done much
>>> in the way of checking past that though, so testing would be welcome.
>>> Given that the patches don't change much in the way of logic, they
>>> shouldn't really affect anything in significant way.
>> [snip]
>> Thanks for the patches - they are excellent ideas. I'll get them
>> implemented when I get back to the US later this week.
> Anytime. I guess the conference spurred some Nagios-hackativity into
> me ;-)
>> For the event queue, I was thinking that a skip list structure might be
>> best for efficiency (http://en.wikipedia.org/wiki/Skip_list). The event
>> queue is used in primarily two situations:
>> 1. Popping events from the head of the list to be executed
>> 2. Inserting events into the list (mid- or endpoint).
>> #1 is very efficient with a linked list, but performance with #2 can be
>> quite bad in large lists. Since a check event usually appears for each
>> host/service that is defined, this can lead to bad performance - O(n^2)
>> I believe - with large installations. A skip list would bring the
>> performance closer to O(log n).
>> Anyone have comments/experiences they care to share about the
>> performance of skip lists and/or better alternatives?
> A skiplist would probably do wonders. I've been experimenting with one
> now, actually using the timestamp for when next to execute
Scratch that. I only glossed the skiplist page you linked, and
misunderstood completely. I've been experimenting with a hash, except
the time used for input is the key. Implementation is trivial and
performance improvement should be fairly close to or better than a
skip-list.
In particular, I'm worried about this snippet:
Insertions and deletions are implemented much like the corresponding
linked-list operations, except that "tall" elements must be inserted
into or deleted from more than one linked list.
I'm sure it'd be good if one gets it completely right, but it sounds
non-trivial, and with a large object base (100k list-nodes or more),
I'm guessing that "inserted into or delete from more than one
linked list" will eat up the performance gains, unless one sacrifices
lots of memory to keep a very large number of "buckets", although I
fail to see how that would help, since one would then have to walk
a larger number of lists in order to find the right one.
Hmm... I'll have to read that article top to bottom (and when it's
not 2AM), it seems.
OP5 AB www.op5.se
