------=_Part_564_1446490.1197642116750
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
for my distributed monitoring it would be great if i where possible to
say:
Use the Template and not the option set in the definition.
My problem is that when i have an active check on an distributed server it
is passiv on the master.
I control this beavior with the template system (diffrend templates on
maser/slave)
But i if use check_freshness on the master it will use the check_command an=
d
f.e pings the Host which could get me the wrong results
if for example the ip address on both location pingable but differend serve=
r
i will get the wron result.
so it would be great if i can say in the template use the check_command
(check_dummy) defined in the template and not that defined in the Host.
Mark
--=20
Mark Eisenbl=E4tter
Geissendoerfer & Leschinsky GmbH
www.gl-sytemhaus.de
Content-Type: text/html; charset=ISO-8859-1
Hi,for my distributed monitoring it would be great if i w=
here possible to say:Use the Template and not the option set in t=
he definition.My problem is that when i have an active check on an =
distributed server it is passiv on the master.
I control this beavior with the template system (diffrend templates on =
maser/slave)But i if use check_freshness on the master it will use =
the check_command and f.e pings the Host which could get me the wrong resul=
ts
if for example the ip address on both location pingable but differend s=
erver i will get the wron result. so it would be great if i can say=
in the template use the check_command (check_dummy) defined in the templat=
Mark-- Mark Eisenbl=E4tterGeissendoer=
fer & Leschinsky GmbHwww.gl-=
sytemhaus.de
------=_Part_564_1446490.1197642116750--
