[Nagios-devel] cgi.cfg: Line 15 (Unknown Variable)
Please let me know if this is the wrong list....
I've recently installed v2.0b4. And find that I get the follow error
when I try to check the cgi.cfg file:
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D
Error in configuration file '/usr/local/nagios/etc/cgi.cfg' - Line 15
(UNKNOWN VARIABLE)
=3D=3D=3D=3D=3D
You can find further info below:
=3D=3D=3D=3D=3D
/usr/local/nagios/etc# ../bin/nagios -v nagios.cfg
Nagios 2.0b4
Copyright (c) 1999-2005 Ethan Galstad (http://www.nagios.org)
Last Modified: 08-02-2005
License: GPL
Reading configuration data...
Checking services...
Checked 62 services.
Checking hosts...
Checked 17 hosts.
Checking host groups...
Checked 1 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 2 contacts.
Checking contact groups...
Checked 2 contact groups.
Checking service escalations...
Checked 1 service escalations.
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 34 commands.
Checking time periods...
Checked 4 time periods.
Checking extended host info definitions...
Checked 0 extended host info definitions.
Checking extended service info definitions...
Checked 0 extended service info definitions.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Things look okay - No serious problems were detected during the pre-flight =
check
=3D=3D=3D=3D=3D
=3D=3D=3D=3D=3D
/usr/local/nagios/etc# ../bin/nagios -v cgi.cfg
Nagios 2.0b4
License: GPL
(UNKNOWN VARIABLE)
***> The name of the main configuration file looks suspicious...
Make sure you are specifying the name of the MAIN configuration file o=
n
the command line and not the name of another configuration file. The
main configuration file is typically '/usr/local/nagios/etc/nagios.cfg=
***> One or more problems was encountered while processing the config files=
=3D=3D=3D=3D=3D
/usr/local/nagios/etc# ls -al
total 80
drwxrwsr-x 3 nagios nagios 4096 Aug 12 15:08 .
drwxrwsr-x 8 nagios nagios 4096 Aug 11 22:51 ..
-rwxr-xr-x 1 nagios nagios 9558 Aug 14 00:22 cgi.cfg
-rwxr-xr-x 1 nagios nagios 30678 Aug 13 10:28 nagios.cfg
-rwxr-xr-x 1 nagios nagios 21437 Aug 12 15:07 nagios.cfg_src
drwxr-sr-x 2 nagios nagios 4096 Aug 12 15:08 samples
=3D=3D=3D=3D=3
...[email truncated]...
