--------------040607000304070109090405
I've finally had some time to clean up the base/Makefile.in.
Here's what it does, with short rationale.
CFLAGS settings changed a bit;
@DEFS@ and -DNSCORE must always be included, so + them on last.
There's no real reason to include the entire set of CFLAGS_WARN
explicitly in the flags overriding the default, since the effect is
identical if they're applied later.
$(SRC_XDATA) shouldn't be explicitly mentioned for each buildrule (poor
normalization).
nagios.o should be among the objects, so that linking and compiling can
be two separate stages also in the rules. This also allows for faster
re-compilation when modifications are done.
Targets that doesn't produce output files should be marked as .PHONY.
Apply with patch -p1 < nagios-base-Makefile.diff.
OP5 AB www.op5.se
Lead Developer
name="nagios-base-Makefile.diff"
Content-Disposition: inline;
filename="nagios-base-Makefile.diff"
diff -urN ../nagios.orig/base/Makefile.in ./base/Makefile.in
--- ../nagios.orig/base/Makefile.in 2004-12-10 15:38:08.000000000 +0100
+++ ./base/Makefile.in 2005-05-22 17:43:36.000000000 +0200
@@ -11,16 +11,19 @@
SRC_XDATA=../xdata
CC=@CC@
-CFLAGS=@CFLAGS@ @DEFS@ -DNSCORE
+CFLAGS=@CFLAGS@
# Compiler flags for optimization (overrides default)
-#CFLAGS=-O3 -Wall -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wstrict-prototypes -Wmissing-prototypes -Wnested-externs -DHAVE_CONFIG_H -DNSCORE
+#CFLAGS=-O3 -fomit-frame-pointer -momit-leaf-frame-pointer -funroll-loops
-# Compiler flags for optimization (complements default)
+# Compiler flags for optimization (complements default or optimize flags)
#CFLAGS_WARN=-Wall -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wstrict-prototypes -Wmissing-prototypes -Wnested-externs
#CFLAGS_DEBUG=-ggdb3 -g3
#CFLAGS+=$(CFLAGS_WARN) $(CFLAGS_DEBUG)
+# These must be present, so make sure they are
+CFLAGS+=@DEFS@ -DNSCORE
LDFLAGS=@LDFLAGS@
LIBS=@LIBS@
@@ -51,18 +54,18 @@
CP=@CP@
# External data I/O code and headers
-XSDC=@XSDC@
-XSDH=@XSDH@
-XCDC=@XCDC@
-XCDH=@XCDH@
-XRDC=@XRDC@
-XRDH=@XRDH@
-XODC=@XODC@
-XODH=@XODH@
-XPDC=@XPDC@
-XPDH=@XPDH@
-XDDC=@XDDC@
-XDDH=@XDDH@
+XSDC=$(SRC_XDATA)/@XSDC@
+XSDH=$(SRC_XDATA)/@XSDH@
+XCDC=$(SRC_XDATA)/@XCDC@
+XCDH=$(SRC_XDATA)/@XCDH@
+XRDC=$(SRC_XDATA)/@XRDC@
+XRDH=$(SRC_XDATA)/@XRDH@
+XODC=$(SRC_XDATA)/@XODC@
+XODH=$(SRC_XDATA)/@XODH@
+XPDC=$(SRC_XDATA)/@XPDC@
+XPDH=$(SRC_XDATA)/@XPDH@
+XDDC=$(SRC_XDATA)/@XDDC@
+XDDH=$(SRC_XDATA)/@XDDH@
# Extra base code
BASEEXTRALIBS=@BASEEXTRALIBS@
@@ -73,49 +76,37 @@
BROKER_H=@BROKER_H@
# Object data
-#ODATALIBS=$(SRC_COMMON)/objects.c $(SRC_XDATA)/$(XODC)
-#ODATAHDRS=$(SRC_INCLUDE)/objects.h $(SRC_XDATA)/$(XODH)
ODATALIBS=objects-base.o xobjects-base.o
ODATAHDRS=
ODATADEPS=$(ODATALIBS)
# Retention data
-#RDATALIBS=sretention.o $(SRC_XDATA)/$(XRDC)
-#RDATAHDRS=$(SRC_INCLUDE)/sretention.h $(SRC_XDATA)/$(XRDH)
RDATALIBS=retention-base.o xretention-base.o
RDATAHDRS=
RDATADEPS=$(RDATALIBS)
# Comment data
-#CDATALIBS=$(SRC_COMMON)/comments.c $(SRC_XDATA)/$(XCDC)
-#CDATAHDRS=$(SRC_INCLUDE)/comments.h $(SRC_XDATA)/$(XCDH)
CDATALIBS=comments-base.o xcomments-base.o
CDATAHDRS=
CDATADEPS=$(CDATALIBS)
# Status data
-#SDATALIBS=$(SRC_COMMON)/statusdata.c $(SRC_XDATA)/$(XSDC)
-#SDATAHDRS=$(SRC_INCLUDE)/statusdata.h $(SRC_XDATA)/$(XSDH)
SDATALIBS=statusdata-base.o xstatusdata-base.o
SDATAHDRS=
SDATADEPS=$(SDATALIBS)
# Performance data
-#PDATALIBS=perfdata.o $(SRC_XDATA)/$(XPDC)
-#PDATAHDRS=$(SRC_INCLUDE)/perfdata.h $(SRC_XDATA)/$(XPDH)
PDATALIBS=perfdata-base.o xperfdata-base.o
PDATAHDRS=
PDATADEPS=$(PDATALIBS)
# Downtime data
-#DDATALIBS=$(SRC_COMMON)/downtime.c $(SRC_XDATA)/$(XDDC)
-#DDATAHDRS=$(SRC_INCLUDE)/downtime.h $(SRC_XDATA)/$(XDDH)
DDATALIBS=downtime-base.o xdownti
...[email truncated]...
