Re: [Nagios-devel] Arguments to check commands (including macros)
In message ,
Paul Dubuc writes:
>William Leibzon wrote:
>> Don't use macros as arguments to commands at service definition. I
>> don't think this was ever documented in nagios 3 as being ok either
>> even if it worked....
>I sure hope this continues to work. I think it allows us to write much
>simpler command objects that can more easily be reused by different
>services.
>Command definitions are often kept in a separate file. It makes the
>service definition much more readable and maintainable if all the
>service specific args (including user defined macros which are
>defined in the service definition or a template used by it) are
>passed to the command in the service definition.
I have to agree. I have many commands defined with parameters that are
required for every service and I use macros to supply the value.
Specifying them in the command definition makes much more sense and is
less error prone IMO.
-- rouilj
John Rouillard
My employers don't acknowledge my existence much less my opinions.
