Re: [Nagios-devel] Nagios external commands (2)
Hi Andreas, hi list,
thanks for this good thread and your time.
> > Working with the External Commands documentation at nagios.org I got
> > the impression that it is written manually and stored in some kind of
> > content management system.
> True. This must be so, or the docs might not match the reality in the
> code.
Hopefully, the docs do not match the reality in the code! There are
some unlovely mistakes in it. Until today I thought this are just
typos, because code and docs are maintained apart.
My approach would be to maintain the XML file with two ideas behind.
- it is an independent program understandable format describing the
supported commands
- it can be used to generate a more readable documentation
> > With a XML file describing the Nagios
> > External Command Interface you could generate the documentation e.g.
> > by XSLT.
> > Why should you do that? Because it would be possible to send patches
> > for the documentation in a program understandable diff format.
> But it already is. The program creating such program understandable diffs
> is called (surprise, surprise) "diff". The program that understands those
> diffs is called "patch". ;-)
Surprise: I know these programs. ;-) And I would use them to send
patches for the documentation. But I am not convinced that this will
work fine. How to send patches for files generated by a content
management system?
Besides that this would only correct the documentation not the API. I
am convinced that documentation has to be generated out of the program
code, so documentation always matches the API and every change to the
API is reflected immediatly in the documentation. Other programs are
using the API. How can they handle changes without changing the
program code? With a format independent description of the API. These
ideas result in: API -> description -> documentation.
> Seriously though, like I said above, the docs need to be maintained along
> with the code, or the doc-to-code relation might get broken for a certain
> revision of either.
Agreed, this is the right approach. But there is no description of the
API yet, so I decided to start with it. In future the description
should be generated automatically out of the API. That's why I think
it is important to Nagios and this mailing list.
> > Actually we are going to work on a concept for an even more
> > distributed environment. Right now all distributed monitoring systems
> > are located at one datacenter location. But we want to roll out Nagios
> > to other datacenters at remote locations too. The idea is to give the
> > remote datacenter as much as autonomy as possible e.g. keep
> > notifications local at each location.
> Sounds like a good idea. I'd use a NEB to propagate the commands if I
> were you, or a separate program altogether.
What about NEBs, are they incorporated within the Nagios code base
after some discussions and code quality reviews, e.g. like kernel
modules?
> > Nethertheless we want just one central console to control the Nagios
> > infrastructure, for example to enable / disable notifications. So you
> > have to control Nagios by an interface you can send commands to from a
> > central system. These commands should be checked if they are correct
> > before they are passed into the pipe.
> Why? They must still be checked for correctness inside Nagios. Adding
> another point of failure might mean you get bitrot in the xml-doc, so
> your commands (which nagios would understand perfectly) don't go through.
> Otoh, if you update the xml-doc prematurely, you would get "OK" from the
> XML validation thingie and then Nagios wouldn't grok it anyways.
Because of multiple reasons. First of all: all input should be checked
before passed to a program, so just writing a program which is able to
write anything to the pipe you want to would be bad.
Second: A tool should support its users and give some explanations
about its usage, in this case some informations about the API.
Third: Quality control and versioning. How is versioning of the API
today realized? Just by changing
...[email truncated]...
