Re: [Nagios-devel] [patch] Fix compiler warnings
Stephen Gran wrote:
> diff --git a/cgi/cmd.c b/cgi/cmd.c
> index df5fc72..2a37a08 100644
> --- a/cgi/cmd.c
> +++ b/cgi/cmd.c
> @@ -1891,6 +1891,26 @@ void commit_command_data(int cmd){
> return;
> +static int cmd_submit(int id){
> + char cmd[MAX_EXTERNAL_COMMAND_LENGTH];
> + const char *command;
> + int len;
> + command = extcmd_get_name(id);
> + * We disallow sending 'CHANGE' commands from the cgi's
> + * until we do proper session handling to prevent cross-site
> + * request forgery
> + if (!command || (strlen(command)> 6&& !memcmp("CHANGE", command, 6)))
> + return ERROR;
> + len = snprintf(cmd, sizeof(cmd) - 1, "[%lu] %s;", time(NULL), command);
> + if (len + return ERROR;
> + return write_command_to_file(cmd);
> __attribute__((format(printf, 2, 3)))
> static int cmd_submitf(int id, const char *fmt, ...){
> @@ -1925,7 +1945,6 @@ static int cmd_submitf(int id, const char *fmt, ...){
> /* commits a command for processing */
> int commit_command(int cmd){
> - char command_buffer[MAX_INPUT_BUFFER];
> time_t current_time;
> time_t scheduled_time;
> time_t notification_time;
> @@ -1980,7 +1999,7 @@ int commit_command(int cmd){
> case CMD_STOP_ACCEPTING_PASSIVE_HOST_CHECKS:
> case CMD_START_OBSESSING_OVER_HOST_CHECKS:
> case CMD_STOP_OBSESSING_OVER_HOST_CHECKS:
> - result = cmd_submitf(cmd,"");
> + result = cmd_submit(cmd);
> break;
> /** simple host commands **/
Instead of adding another function doing pretty much the same, but
without any variable arguments on the function call, you might have a
look at Andreas Ericsson's patch by checking fmt for NULL, and replacing
the string literal by NULL.
http://git.op5.org/git/?p=nagios.git;a= ... acbba27e3a
It's nicely resolved and keeps the upstream clean for other NULL'ed
arguments.
Kind regards,
Michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
fax: +43 1 4277 14279
web: http://www.univie.ac.at/zid
Icinga Core& IDOUtils Developer
http://www.icinga.org
