> hey andreas,
> On Fri, Feb 24, 2006 at 11:38:46AM +0100, Andreas Ericsson wrote:
>>> seed=(int)time(NULL)*311-getpid()*359+getppid()*383;
>>>which makes remote attacks on the prng more or less impossible, and local
>>>ones difficult at best. i'm not sure why you would need to call it
>>>multiple times.
>>Unfortunately it doesn't. It's possible to determine what a hosts system
>>clock is set to by either watching ntp traffic to/from the host (with
>>great accuracy), or by watching arbitrary packets sent from the host
> but the remote attacker would not know the pid/ppid, correct?
> or did you mean that it doesn't for the local attacker? it's still
> within the realm of feasibility, though i'd posit it's still a
> modest improvement over a 1-byte seed value.
Ah, sorry for not explaining that. pid and ppid can usually be guessed
with some accuracy by checking what sort of system it's running
(preferrably what distribution it is), and then installing or checking
on a similar system what pid and ppid it would get when booted. Most
daemons are started at boot-time, so it's usually a fairly close guess,
and then start trying brute-forcing with guessed_value +- 50.
With enough computer power one could simply guess at pids between 300
and 600. Usually it's within that range. If SNMP is running with
read-only "public" enabled (fairly common in corporate networks), the
pid can usually be determined exactly.
>>True. It would be far better to read a full int. For time-seeding it's
>>preferrable to xor-fold a timeval-struct into an int, like so:
>>gettimeofday(&tv);
>>sec = (int)(tv.tv_sec ^ tv.tv_sec >> (__WORDSIZE - 32));
>>usec = (int)(tv.tv_usec ^ tv.tv_usec >> (__WORDSIZE - 32));
>>seed = sec ^ usec;
> agreed--that's a nice trick i hadn't heard of. would it be worth
> putting in some local information as well (getpid()?), or is the
> granularity of the usec field enough that a remote attacker couldn't
> estimate the value? anyway i'm putting that down in in my notes for
> future reference
It could be extended by
pid_seed = getpid()
>>You would have to read an exceedingly large data-set from the random
>>devices to drain it of entropy. The PRNG (in Linux at least) loops after
>>2^64 bytes unless the state is continuously and additively seeded (which
>>it is).
> i don't know enough about random devices, but had recieved complaints
> from a couple folks about the issue of "useless entropy draining". not
> knowing more, and seeing a problem i did understand (1-byte seeding)
> i went ahead and applied the patch.
Understandable. I had this same view before I read the PRNG-code in the
kernel (and before I tried my hand at writing a couple of them in some
daemons). The timeval xor-folding is actually pretty neat. Most kernels
don't have true microsecond-precision (although they try to pretend they
do), so the value fluctuates and is hard to determine for both remote
and local attackers.
OP5 AB www.op5.se
