Re: [Nagios-devel] Host and Services update fonction called twice
Julien Mathis wrote:
> Hi,
> After every single host and service check, the update functions of the
> broker is called twice. These functions are update_service_status and
> update_host_status. So the status is also sent twice to ndo2db. This bug
> increases network traffic and DB requests.
> I hope somebody can do something about it,
Are you sure this happens twice *after* the check is completed? It's
supposed to happen twice, but once before and once after the check is
actually executed. This is a very important feature, as modules such
as DNX rely on it to highjack immediately pending checks to distribute
to its poller nodes.
So can you please verify that it happens twice *after* the check is
actually completed? If so, that's a bug and I'll fix it.
> Thanks for your help.
Thanks for the report.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
