Re: [Nagios-devel] [PATCH] Unused variables x and found_macro_x on
----- Original Message -----
> On 06/22/2012 08:57 PM, Ricardo Maraschini wrote:
> > hello,
> >=20
> > i've removed two unused variables on found_macro_x() function.
> > Compiler errors:
> >=20
> > ../common/macros.c: In function =E2=80=98process_macros_r=E2=80=99:
> > ../common/macros.c:133:6: warning: variable =E2=80=98found_macro_x=E2=
=80=99 set but
> > not used [-Wunused-but-set-variable]
> > ../common/macros.c:128:6: warning: variable =E2=80=98x=E2=80=99 set but=
not used
> >=20
> >=20
> > OK? Comments?
> >=20
>=20
> Test this with macro resolution debugging turned on. I just
> reverted a patch that did this change (and a bunch of other
> -Wunused-but-set-variable), and removing the unused ones
> actually broke macro resolution for the core.
Just for curiosity, the patch you've reverted had the same logic as mine re=
garding strcmp()?
-rm
