Re: [Nagios-devel] Patch for Circular Paths (new algo) 70s->0.007s
------=_Part_8363_28739224.1201977143026
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Hi list,
I test a difficult sample (like your one Andreas). The test.cfg is the
configuration file for nagios, and circular_check.png is a image of
the configuration, and all the loops :)
Red items are bad: the are in loops, green are OK. Red items need to
be in error state, and just them. I realize my previous patch showed
too much errors when a host was in 2 differents loops. Now It's OK.
I change the output of my patch to fit exactly to the original output.
You can use test.cfg and had some nasty parents relations, and see if
the patch show all errors.
Jean
On Feb 1, 2008 11:44 AM, nap wrote:
> Hi,
> Here is the patch without the space. I just test it and it apply to
> the cvs version.
> I'll check for the object.cache and try to make mode funny samples
> (I'll become a master of awk after that...). I think the exemple you
> give will be ok with my algo (it's a standard algo for check graphs),
> and we check a node one and only one time so no problem with
> complexity I think. I'll post the sample, but if you already have some
> special case, I take them :)
> You can see the test.cfg. It's the sample with a loop. But it's a simple loop.
> I'm ok with your conclusion, if the algo if false, it's useless ;)
> I'll work for big complex sample this week-end, if you don't post the
> results monday, it's that i'm dead while reading the man of awk.
> After that, I'll trace the services dependencies check.
> Jean
> > > nap wrote:
> > >> Hi list,
> > >> I finish my patch for the host path part. I try to folow the
> > >> indentation and the coding style of nagios.
> > > It looks a lot better now. For extra points, remove the hunks that
> > > only insert whitespace changes.
> > >> you can find test files with a lot of parent/childs at
> > >> http://zegabes.free.fr/nagios/ .
> > > What's lacking from that place is the objects.cache using the old
> > > code and one generated using the new one, especially with multiple
> > > parents, as well as a diff between them so one can see what, if any,
> > > the differences are.
> > I take that back. What's lacking is a proper test-case. If the config
> > you've been using to test is the one on that site, you haven't even
> > scratched at the funnier configs one sometimes see.
> > For now, you're doing a "parent -> 100 children" thing, which is
> > obviously quite quick and very simple to get correct values for.
> > Will your algorithm work for something like this?
> > parent2 parent8 ----------
> > parent0 - parent3 - parent5 - parent6 - parent7 \
> > parent4 parent9 - parent10 - endhost
> > parent11-----------------------------------------------------------
> > Which is indeed a rather messy and complex scheme, but something that
> > nagios should handle (it does today, so it has to do so tomorrow too).
> > Optimizing for speed in the simple (and probably most common cases) is
> > all fine and good, but if things suddenly break horribly for 15-20% of
> > the user-base, it isn't worth a thing.
> > Andreas Ericsson [email protected]
> > OP5 AB www.op5.se
> > Tel: +46 8-230225 Fax: +46 8-230231
> > This SF.net email is sponsor
...[email truncated]...
