Re: [Nagios-devel] A couple of new feature requests
------=_Part_52120_22999534.1156237648005
Content-Type: text/plain; charset=UTF-8; format=flowed
Content-Disposition: inline
As mentionned the logout functionnality is not Nagios related but browser or
web-server related.
It's possible to change the behaviour of the apache authentication mechanism
to provide a sort of logout functionnality. To do this you'll need to use
mod_perl or mod_python (or some other kind of apache module) to handle the
authentication/authorization mechanism.
Some information about this can be found here:
http://raburton.lunarpages.com/apache/mod_auth_cookie/
http://search.cpan.org/~mschout/Apache- ... hCookie.pm
http://www.modpython.org/live/current/d ... cated.html
A running example can be found here:
http://runnagios.be (login: demo password: Nagios2)
and some implementation information:
http://www.barbich.net/websvn/wsvn/docs ... rev=0&sc=0
Using this king of authentication systems has multiple advantages: multiple
authentication bases, session timeout, date/time restrictions ... but this
can get a bit complicated to setup.
Seb.
On 8/21/06, Thomas Guyot-Sionnest wrote:
> > -----Original Message-----
> > From: [email protected]
> > [mailto:[email protected]] On Behalf
> > Of Jason Martin
> > Sent: August 19, 2006 18:44
> > To: nemir nemiria
> > Cc: [email protected]
> > Subject: Re: [Nagios-devel] A couple of new feature requests
> > On Sat, Aug 19, 2006 at 06:41:40PM +0000, nemir nemiria wrote:
> > > Second request might be a bit harder, and is less useful
> > but it would be
> > > nice to have a logout button. Or if there is one, maybe
> > shift it so that it
> > > is a more intuitive spot. I haven't found one yet...
> > Logout is browser specific, unfortunately no browsers have a
> > 'forget' function for http authentication.
> That's not 100% true, with Firefox you can clear authenticated sessions
> (it
> will clear all of them, however)
> Clear Private Data from the Tools menu, or Ctrl-Shift-Del, then select
> only
> Authenticated Sessions.
> Thomas
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job
> easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=UTF-8
As mentionned the logout functionnality is not Nagios related but browser or web-server related.It's possible to change the behaviour of the apache authentication mechanism to provide a sort of logout functionnality. To do this you'll need to use mod_perl or mod_python (or some other kind of apache module) to handle the authentication/authorization mechanism.
Some information about this can be found here:http://raburton.lunarpages.com/apache/mod_auth_cookie/
http://search.cpan.org/~mschout/Apache- ... cated.html
A running example can be found here:http://runnagios.be (login: demo password: Nagios2)and some implementation information: <a href="http://www.barbich.net/websvn/wsvn/docs ... ntication/
...[email truncated]...
