No able to add new host
Hendrik
Post by Hendrik »
Hi Guys
I just added a new Host and ensured I ticked the active box as yes, tha "apply config" runs succesfully but the host stays "Not Synced", I ended up trying to add various ones even coping working ones and renaming but the system does not want to add anymore hosts, ther are only 10 hosts at current on the server
rdedon
Re: No able to add new host
Post by rdedon »
could you give a precise example of how you are adding the new hosts and also what version of Nagios XI you are using? Thanks!
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
Hendrik
Post by Hendrik »
Hi I am using an image i downloaded last week ( Latest one)
I am adding a host from the core config, I try by either using add new host button or by copying a currently existing one and changing the name.
All new hosts I attempt to add stay on "Active" "not Synced", I have restarted Nagios and check config files without any errors.
Hennie
mguthrie
Post by mguthrie »
Your server's time is probably not synced correctly with your browser. Run:
yum install ntp
ntpdate time.nist.gov  ##(or a local time server)
If that doesn't fix the issue, try the solution posted below.
http://support.nagios.com/wiki/index.ph ... e.22_Error
