[Nagios-devel] SOLVED!: Re: Bug in CVS version? returncode 127
Hi!
I found the reason! I had the recent nagios cvs version running with
"Sample Main Config File for Nagios 3.0b1". So a few parameters where
missing. After I change the Config File to the recent one everything
works fine. But that is why I wonder if the new parameters don't have
any default values. At least the documentation section about upgrading
should remind the user to check the nagios.cfg for extra parameters.
Cheers,
Gerd=20
On Mo, 2008-02-25 at 09:45 +0100, Gerd Mueller wrote:
> Hi Hendrik,
>=20
> of course :-) I checked it more than twice before writing this mail ...
>=20
> After removing the new hosts everything works fine again. So it can't be
> caused by resource.cfg
>=20
> Cheers,
>=20
> Gerd
>=20
>=20
>=20
>=20
> On Fr, 2008-02-22 at 15:13 +0100, Hendrik B=E4cker wrote:
> > Hi Gerd,
> >=20
> > Gerd Mueller schrieb:
> > > Hi list!
> > >=20
> > > What am I missing?
> > >=20
> > > Today I added a few host definitions and restarted nagios afterwards.
> > > Immediately after this restart nearly all my checks ended with: =20
> > >=20
> > > ### Nagios Service Check Result ###
> > > # Time: Wed Feb 20 13:41:12 2008
> > > host_name=3Dddns01
> > > service_description=3Dnet-ssh
> > > check_type=3D0
> > > check_options=3D0
> > > scheduled_check=3D1
> > > reschedule_check=3D1
> > > latency=3D50.458000
> > > start_time=3D1203511272.458201
> > > finish_time=3D1203511272.632000
> > > early_timeout=3D0
> > > exited_ok=3D1
> > > return_code=3D127
> > > output=3D(null)
> > > ### Active Check Result File ###
> > > file_time=3D1203511270
> > >=20
> > >=20
> > > So what's wrong?=20
> > >=20
> > did your nagios user has enough rights to re-read the ressource.cfg=20
> > after a reload?
> >=20
> > Is everything ok with your ressource.cfg?
> >=20
> > Hendrik
> >=20
> > This SF.net email is sponsored by: Microsoft
> > Defy all challenges. Microsoft(R) Visual Studio 2008.
> > http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> > _______________________________________________ Nagios-devel mailing li=
st [email protected] https://lists.sourceforge.net/lists/l=
istinfo/nagios-devel
--=20
Gerd Mueller =20
Senior Consultant
NETWAYS GmbH | Deutschherrnstr. 47a | D-90429 N=FCrnberg=20
Tel: +49 911 92885-0 | Fax: +49 911 92885-33=20
GF: Julian Hein | AG N=FCrnberg HRB18461=20
=20
http://www.netways.de | [email protected]=20
