[Nagios-devel] Re: Nagios-devel digest, Vol 1 #813 - 2 msgs
On Sat, 14 May 2005 [email protected] wrote:
> --__--__--
> Message: 1
> Date: Sat, 14 May 2005 10:29:48 +0100
> From: Dmitriy Kirhlarov
> To: [email protected]
> Subject: [Nagios-devel] freshness check bug?
> Hello, list.
> Confirm the bug finded Bryan Loniewski 2005-05-11.
> When you use fiels
> freshness_threshold any_seconds
> then
> check_freshness 0
> is ignored.
This is not exactly the bug I *believe* to have found.. I am getting inconsistent
behavior with freshness checking (ie, stale results are not always being found, and
sometimes when they are the check_command is not activated and/or the evenhander is not
run, that is if you have one defined).
> Dmitriy Kirhlarov
> OILspace, 26 Leninskaya sloboda, bld. 2, 2nd floor, 115280 Moscow, Russia
> P:+7 095 105 7245 F:+7 095 105 7246 E:[email protected]
> OILspace - The resource enriched - www.oilspace.com
