> Ethan Galstad wrote:
>> Larry Low wrote:
>>> I haven't started to track this one down yet but when using Getopt::Long and
>>> you end your perl command with spaces the ePN will throw an error.
>>> Use of uninitialized value in string eq at
>>> /usr/lib/perl5/5.8.8/Getopt/Long.pm.
>>> I'll try to look into what is going on.
>> Anyone experiencing the same problem or able to come up with a fix? I'm
>> not a Perl guy and I have half a mind to rip out the EPN due to all the
>> issues with memory leaks, etc.
> Make it a NEB, perhaps? I haven't looked at how much trouble that would be,
> since the NEB would only want to fire up the check and then let the result
> be fed back through the normal channels.
> I must confess that all the problems with it has made me refrain from adding
> it to op5 installations at all. None of our customers use it. There are far
> easier fruits to pick if one wants to boost performance.
That's what I was thinking as well. Perhaps that's one of the things
that should be done for Nagios 4.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
