Re: [Nagios-devel] Problem logging criticals after host down
On 22/05/07 05:10 PM, Ricardo José Maraschini wrote:
> Hi Thomas,
> Try to generate an Availability report for affected services ignoring
> SOFT STATES and you will see where problem is.
> The service will becomes OK in avail just when the Nagios logs an HARD
> OK for the service in log files.
Then another way to fix that could be to never ignore a SOFT OK state in
availability reports. That shouldn't break anything since SOFT OK states
should never show after a HARD non-OK states except in the specific case
you mentioned.
I don't know the specific part in Nagios that does that
SOFT-on-host-recovery logic, so I'm not sure which one should be easier
to do.
I don't have time right now, but I might take a look at it later if
nobody else look into that issue.
Thomas
