> On 9 Apr 2007, at 03:59, Ethan Galstad wrote:
>> I think its a good idea to escape HTML whenever possible. I think
>> these
>> kinds of problems can all be avoided by simply escaping the
>> characters. I've updated the html_encode() function and changed the
>> CGIs to encode all plugin/perfdata output in the CGIs, as well as the
>> command definitions in the config CGI. I think I've got the code
>> changed in all the necessary places. Patches will be made the CVS
>> code
>> (Nagios 2.x and 3/HEAD branches) shortly.
> What about where we *do* want html passed through to the web
> interface? For instance, we have urlize which wraps the output with
> an tag.
Whoops - forgot about that.
strip HTML from the plugin output at the moment (original
functionality), but left a strip_plugin_html() stub for stripping out
some tags in the near future.
> I would prefer Sean's suggestion of allowing "safe" tags. My drupal
> install has a "filtered HTML mode" which allows
> , which seems like a
> reasonable list to allow. Any other tags should be stripped, rather
> than just encoded, I think.
Sounds reasonable. I'll get to writing this over the next few days.
> If you agree on a list of allowable tags, I can see this is useful to
> add to the plugins guidelines.
> Especially with Nagios 3's multi line output, some filtered output is
> going to be a very useful way of getting data presented in the front
> end. The front end can also decide whether to display or not.
> I would expect you always encode perfdata and command definitions.
> Ton
> http://www.altinity.com
> T: +44 (0)870 787 9243
> F: +44 (0)845 280 1725
> Skype: tonvoon
Ethan Galstad,
Nagios Developer
Email: [email protected]
